Classic Audi » Technical » Mech/Tech » Suspension & Brakes » HP2 Struts into C3 100 QT
Old 07-07-11, 12:27 PM   #1
Quattro Power
Quattro Power's Avatar
Default HP2 Struts into C3 100 QT
Hi Guys,
I've searched for info on this and couldn't fin any, so sorry if it's been asked before but....
I have a C3 100QT, and 2 x URS4's sitting waiting to be broken, one has nearly new discs & pads, koni yellows and cobra lowering springs, my question is can the HP2 struts be fitted to a C3?
If so whats involved?
Best Regards,
Leigh
Quattro Power is offline   Reply With Quote
Old 07-07-11, 12:34 PM   #2
whats up with the UrS4's ?
your 2 must be 2 of the 4 currently sorned then !! mine is one of them for now but will be back on the road by Sept
any chance of phots of the S4's please
Old 07-07-11, 12:42 PM   #3
Quattro Power
One of them was my daily until it developed a wiring loom fault.......non-starter
Other is a great runner but is rotten as feck.......
The runners engine is going in my B3 80Q , and the non runner may be going in the C3 100QT
Just wondering about this suspension though......mind you I haven't offered it up or even compared, but just thought one of you nutters must have thought about it or tried it by now!!
Old 07-07-11, 01:23 PM   #4
if you have ignition on the non starter, have you tried vag com on it? could be something simple
pity to break if its easy to fix. pity your up on Shetlands!!
are either of them autos?
Old 07-07-11, 01:30 PM   #5
Quattro Power
No Fault codes, tried everything, it's definately not anything on the engine side, it's a problem between the plugs at the bulkhead and the ECU??......ECU's fine, along with everything else that's been suggested, I went through a massive thread discussion on S2forum about it! I reckon it's a broken wire / wires in the wiring loom PITA
Old 07-07-11, 01:39 PM   #6
is it cranking over? but no start? could be fly wheel position indicator
