Classic Audi » Technical » Mech/Tech » Engine » Distributor end float KV
Old 04-05-24, 06:51 PM   #1
Duffy3074
Default Distributor end float KV
Hey troops
still chasing a regular flat spot on E-Lad
My distributor has about 3mm of endfloat but very little side float
The rotor arm must be getting pushed upwards as this spins up and the shaft turns faster
Anybody aware of what it should be?
I'm reluctant just to fire the parts cannon on this one
Duffy3074 is online now   Reply With Quote
Old 05-05-24, 02:29 PM   #2
Colin Aitchison
Colin Aitchison's Avatar
Hi Derek, I have a KV distributor, it is at the unit and I have no plans of visiting the unit till Friday.
Old 07-05-24, 10:34 AM   #3
K Simmonds
K Simmonds's Avatar
A little end float is normal, though 3mm does seem like quite a lot but shouldn't be enough to upset the hall sender. Side to side play should be minimal.
Still have my RS2 tuck up safe, also a 1992 C4 2.8 Avant quattro and a B3 quattro Saloon G60 conversion in progress.
Old 07-05-24, 01:01 PM   #4
BackintheFold
BackintheFold's Avatar
Originally Posted by Duffy3074 View Post
Hey troops
If the effect of the float is (say) moving the arm 10Deg BTDC at full chat, try setting the dizzy so its 10Deg ATDC at rest.
Then it will spin up to the "correct" position when you are encountering the flat spot.
If it cures it at speed, then look to replace or repair the dizzy.
Woudl it be possible to use washers to remove that float?
2014 S3 (daily drive)
1987 MB ur
Old 15-05-24, 04:44 PM   #5
Duffy3074
Thanks guys
Colin any chance of checking yours at some point and seeing how much endfloat there is?
Old 15-05-24, 06:15 PM   #6
Colin Aitchison
Forgot to look last week, text me on Friday.
Old 15-05-24, 10:09 PM   #7
Duffy3074
Wildo
