Members: 43,064 | Total Threads: 40,086 | Total Posts: 471,052 Currently Active Users: 6521 (1 members and 6520 guests) Welcome to our newest member, JeffreyVak |
Hi folks,
Haven’t dropped in for a while, but I’m looking for a how to guide, with pics would be good, for how to change out the slave and master cylinder on my rr urq. The pedal gave up the ghost end of last year and I’ve now got no clutch, bugger, and I’d like to get it on my 2-poster and get both changed out before April/May when the non salted roads are back! I’ve got both cylinders waiting, what else will i need? Which fluid? Any nuts and bolts or pins that I’ll need to get? TIA |
No picture guides from me but the slave is only held on by a single M8 bolt and 30 year corrosion. Easier if you shift the steering to the side. If you loosen the hose first, you can then undo the bolt, remove the slave and wind it off the hose
The MC - best guide for that is on Phil Payne's old site. I've heard it's a pain in the Ur but on the S2 it was fairly straightforwards. Fluid is just dot 4 brake fluid
#3 | |
#4 | |
Thanks, I’m sure it’ll become more obvious when i get it on the 2-poster. I think you mean turn the steering wheel one way to full lock so that it move the rack out of the way...?
The slave is at the top of the gearbox not the side ( typo? ) yours will be retained by a bolt which is easier to deal with than the early ones that were held by a roll pin. As above loosen the pipe first and wind the cylinder off it - saves time.
The master is a fiddle to be sure. I always used to maintain that Audi took the heater box and clutch cylinder and then built the car around them! It is a lot easier on a left hand drive car in fairness so it’s just one of the many things that didn’t lend itself to be moved over without redesign. With respect to Phil Payne his instructions are complicated in the extreme and describes a lot of work that is not required. There is no need to remove the drivers seat or the steering wheel and switch gear let alone the throttle pedal. In the day I replaced, literally, dozens of these and never had need to destroy clips so that one confuses me. Generally speaking release the reservoir in the scuttle so the feed pipe can be pulled through a little. Remove the under dash and pedal trim. Remove the lower steering column (one bolt and slide it up and off). Remove bolts and nuts holding the pedal box in ( not forgetting the one hidden in the engine bay on the other side of the fire wall). The pedal box can then be pulled down enough to access the cylinder. Undo the pressure pipe, lever out the feed pipe (plenty of rags to catch fluid) two nuts and bolts and pull the cylinder of the actuating rod ( don’t remove the rod) if your new cylinder comes with a threaded rod ( the genuine ones did) then discard it. As I said, in the past I have done dozens so I accept it’s easy for me to say but it’s not difficult so much as fiddly |
Hi Gmac how is it going,
Great advice form the rest of the guys. Slave cylinder is ok just a bit of a stretch. Master cylinder, I would ask you to consider removing the pedal box and disconnecting the brake linkage and removing the pedal box from the car, removing the master cylinder and refitting it and then replace the pedal box, more advice, make sure the drivers side door is open fully before you lift the car on the two post lift as this will aid access to get into the foot well area, its just a bugger when the car is up in the air and need to come off the lift to open the door fully, after removing the under dash tray that has the ECU attached to it you will get a better view of the access problem, you may also need to remove the drivers seat, again for access. |
it has been known for the slave to corrode itself to the gearbox so much that when its been persuaded out part of the gearbox cracks off,be careful as that will be a bad day
