Classic Audi » Community » General Chat » Intercooler query
Old 10-03-16, 11:12 PM   #1
Jake Blight
Jake Blight's Avatar
Default Intercooler query
If a turbo vehicle has had an upgraded intercooler fitted and the owner states that the thermostat had been removed to aid cooling...Would that sound plausible? It's a very beetle cup car 1.8t.
Cheers for any help.
Jake Blight is offline   Reply With Quote
Old 10-03-16, 11:35 PM   #2
jimh
No, not really.
An upgraded intercooler would lower inlet temperature, creating more power (assuming the required extra fuel can be provided). Cooler air is more dense, so having cooler air will produce the same kind of effect as having more air.
Removing the thermostat would just mean the engine would take much longer to reach operating temperature, then over cool when cruising. Both of these are bad as it will waste fuel, cause faster engine wear and soot up the exhaust / cat(s) /plugs.
If it was overheating before then the reason should have been determined. Bad thermostat / bad water pump / bad radiator etc.
Or the car has been modified enough to create more engine heat than the stock cooling system can handle in which case a larger radiator may be required.
Old 10-03-16, 11:42 PM   #3
Jake Blight
Cheers for that..
Old 11-03-16, 08:57 AM   #4
4v6
Best engine powers usually made at an engine temp of 73 ish degrees iirc, so get a thermostat that keeps the engine in that range.
No thermostat means an engine will be overcooled as per JimH's post.
