Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,121 Currently Active Users: 5545 (0 members and 5545 guests) Welcome to our newest member, BuddyInons |
I have a problem that has been steadily getting worse for the last 2 weeks or so. I will fire up in the morning, 1st time, straight away, I drive say to a petrol station, fill up, restart, it wont! I leave it 5-10 mins, turn the key, hey presto it fires straight up. Today I drove down to the coast, stopped, parked up, switched it off. Went to fire her up, nothing. Waited 10 mins, turned the key, it fired straight up.
Any ideas? When it fails, it comes on, but immediately the revs drop, and it stalls.
I had a similar situation, try the cold start relay probably sticking, remove and re-insert
Coupe Quattro 1985
I had a hot start problem with my UR when I first got it. Turned out to be something to do with the fuel pump if I recall (back before I was active in getting oily myself!)
Thanks dave, moonwatcher and ken, at least I've got things to look at.
#5 | |
Whereabouts is the relay? Not listed in the haynes or bentley book? Many thanks. Andy
had the same problem on my 2.3e and it turned out to be metering head fault
Had a similar problem,turned out to be fuel pump relay.
When it cut out,I'd have to wait about 15 minutes before it would restart. ![]()
This problem is getting worse and worse, so is the next issue to get sorted!!
Where will I find the cold start relay please
It's good that we can guess that we're talking about KV engine...
There's no "cold start relay" - there's only switch which turns on cold start injector when starter motor is running. The rest of enrichment is provided by control pressure regulator. |
Thanks for the reply msh. Yes its the kv engine. I want to eliminate the simple things first. Any thoughts you might have would be much appreciated.
