Classic Audi » Technical » Mech/Tech » Electrical problems » Wiring diagram for hood release switch
Old 03-01-15, 08:35 AM   #1
Aud
Default Wiring diagram for hood release switch
Hello,
Does anybody have schematics for the switch on the B-post? To release the locks on a manual top?
Best rgds!
Aud is offline   Reply With Quote
Old 07-01-15, 05:58 AM   #2
Aud
Nobody?
Old 07-01-15, 10:18 AM   #3
Val
Val's Avatar
This car?
Val is offline   Reply With Quote
Old 07-01-15, 11:17 AM   #4
Aud
Originally Posted by Val View Post
This car?
I wish!
Sorry!! My mistake!
It's a -93 80 2.3
Old 23-02-15, 02:02 PM   #5
Cyberplod
Cyberplod's Avatar
I have not got a schematic, but it is really simple. A single live wire in, a pressure switch that, when pressed, passes power to the catches in the hood storage locker. Unfortunately, on my '94 model, the power in was OK, the switch worked OK, but the catches still refuse to open electrically. I would have expected a relay but can't find one anywhere. It's "on my list" and if I get a result I will post back.
Cyberplod is offline   Reply With Quote
Old 23-02-15, 09:02 PM   #6
vee six
vee six's Avatar
There's an ECU behind the rear seat back, often problematic due to dry solder joints.
I removed mine and spent ages carefully going over every soldered joint; refitted it and the bloody hood release still won't work!
I can hear the ECU clicking when I press the release button, but that's as far as it goes. I still have to release it manually - admittedly that's not difficult, but I would like it to work correctly.
Let me know if you need more info on accessing the ECU.
HTH,
Alan
2016 S6 Avant 4.0T
2012 Q3 quattro 2.0TDi (missus' car)
1983 Laverda RGS1000 (#1 toy since 1989)
1977 Laverda 1200
2021 Moto Guzzi V85TT
has-beens:
'83 80GL/'83 100CS/'82 80CD/'88 90 2.2E/'03 A4 1.9TDi/'94 Coupe 2.0 16v/'87 Coupe GT/'96 A4 Avant SE 2.6 V6 356k miles/'02 A6 2.7T quattro avant/‘97 2.6 Cabriolet/'07 Allroad 3.0TDi
vee six is offline   Reply With Quote
