Classic Audi » Technical » Mech/Tech » Suspension & Brakes » C4 100 handbrake adjustment
Old 06-07-13, 11:31 AM   #1
keithyboy
Default C4 100 handbrake adjustment
HBOL tells me there's a nut accessed via a hole in a heatshield but doesn't give me a clue as to where.
Any ideas?
keithyboy is offline   Reply With Quote
Old 07-07-13, 10:32 AM   #2
Andy10v
Andy10v's Avatar
I use a long extension from the rear of the car, slide it in where the heat shield ends.
2005 350z GT
Sold-1993 ABY coupe
Old 07-07-13, 03:49 PM   #3
Hanuman
Hanuman's Avatar
Here's a little pic-
The nut is M6, 10mm a/f. Item #11
It tensions the cables by moving the yoke, #10, along the rod which is attached to the brake lever.
A 1/4 or 3/8 drive ratchet, deep 10mm socket, and several extensions have been sufficient in the past.
A small note of caution, if the history is unknown.
The yoke is actually not symmetrical, as the cables are 2 different lengths. It has to be on the right way around.
Hopefully all is ok, however, the rod has been broken and repaired on a few cars that I've seen; my ur, someone else's type 44, and the scrapper V8. So, make sure the nut can run freely
Old 07-07-13, 07:37 PM   #4
crisarc
or the cables are stretched!!!, i have that joyful job on my new c4
Old 09-07-13, 05:39 AM   #5
If that was C4 FWD, it was joyful job indeed. For quattro that job is noticeably harder, as there's also propshaft present in transmission tunnel, not only exhaust.
