Classic Audi » Technical » Mech/Tech » Suspension & Brakes » coilover spring rate
Old 15-05-13, 12:10 AM   #1
styler
styler's Avatar
Default coilover spring rate
what would you recommend for coilover spring rating for a 90 CD 5 cylinder? i figured around 200 lbs, is that too stiff?
CRASH VALLEY CUSTOMS
get 'er done...
Old 22-05-13, 05:27 PM   #2
styler
styler's Avatar
what are you guys running in your rally cars /shorties ????
get 'er done...
Old 22-05-13, 07:25 PM   #3
Steve
Steve's Avatar
300lb matched all round, 2.5" ID and 8" long.
Steve is offline   Reply With Quote
Old 22-05-13, 07:28 PM   #4
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Well on the front of the QC we have 10"X 260lbs springs and on the back 11" X 240lbs all with Koni adj shocks..
On the 80 we have 10" x 220lbs fronts and the backs are springs from an avant with a little bit of a trim again Koni adj shocks.
But we are just about to up the ones on the coupe to 300lbs and put the 260lbs on the 80.
Old 22-05-13, 07:49 PM   #5
inne3quattro
inne3quattro's Avatar
Wink
Hi Styler, I've done a few sets of coilovers that are being used on group 4 tarmac cars, I used 500 and 450 with 300mm and 280mm length, ID 82mm, with billy inserts.
inne3quattro is offline   Reply With Quote
Old 22-05-13, 08:17 PM   #6
s2rob
I use 500 front and 450 rear on 500 bhp ur Quattro with billy inserts,handles like a go kart but very firm
s2rob is offline   Reply With Quote
Old 22-05-13, 08:49 PM   #7
styler
styler's Avatar
this is for road use, 300+ would be too hard would it?
get 'er done...
Old 23-05-13, 09:10 AM   #8
s2rob
I think 300 is good for the road,mine is a bit harsh at times
Old 23-05-13, 05:01 PM   #9
styler
styler's Avatar
thanks folks..
get 'er done...
