Classic Audi » Technical » Mech/Tech » Engine » Crank Sensor
Old 10-12-12, 07:47 PM   #1
d.batch
Cool Crank Sensor
Hi all, my car is Audi 90 coupe 1990 2.3 7a engine
I’m a little stuck I’m trying to find were crankshaft position sensor is and I’m having no luck, does anyone know where this is having a diagram of where it is.
I’m having problems starting the car up it just keeps turning over but never starts I’ve checked all of the usual even tested the injectors. So the last thing I need to check (I think) is the crack sender, as I’ve been to this send the message to the injectors to put petrol into engine,
If anyone can help it would be greatly appreciated.
Many thanks
David
d.batch is offline   Reply With Quote
Old 10-12-12, 09:22 PM   #2
spink
Crank sensor is on passenger side of engine next to the gearbox,you will see 2 sensors together mounted on an alloy block.i can't remember if its the upper or lower one offhand
Old 10-12-12, 10:52 PM   #3
Tonks4x4
Tonks4x4's Avatar
The one nearest the engine is the firing point sender that picks up the single pin mounted in the flywheel.
The other sensor counts the teeth on the ring gear
http://www.tonks4x4.com
Old 10-12-12, 10:57 PM   #4
another thing worth looking at is the drive gear on the dizzy. The original ones on the 7a engine were bakelite and have a tendency to break down and will give you the same symptoms. You can replace these with the brass gear. Think it was quattrorob who was selling these.
Old 11-12-12, 04:18 PM   #5
Sounds like a no spark problem.
It's very rarely the crank sender.
1991 90 quattro
Old 11-12-12, 04:28 PM   #6
aye and points more to the dizzy drive gear.
http://www.ebay.co.uk/itm/Audi-90-Co...cfd6456&_uhb=1
get one of these to replace it.
Old 11-12-12, 06:20 PM   #7
Tonks4x4
Tonks4x4's Avatar
Just take the cap off first and see if the rotor is spinning when cranking.
If it is spinning smoothly all the way round the drive gear is currently intact.
Old 11-12-12, 06:22 PM   #8
quattrostyle
So what does a crack sensor actually do?
Old 12-12-12, 12:20 AM   #9
missfire
missfire's Avatar
It finds crack! Which ain't so easy in this neck of the woods I can tell you, the Police do a very good job of finding it all, before I do..
Old 12-12-12, 07:26 AM   #10
quattrostyle
Ah bummer, no problem here even without a crack sensor
