Classic Audi » Technical » Mech/Tech » Electrical problems » Electrical nightmare, please help.
Old 17-02-13, 02:58 PM   #1
baron2211
baron2211's Avatar
Default Electrical nightmare, please help.
Three weeks ago yesterday MY 1987 200 quattro began blowing its 25 amp fuse that controls the AC radiator fan, wipers and indicators.
After much diagnostics that involved disconnecting each and every item that was on that fuse, the problem was traced to the wiring that went into the tailgate. This was replaced and all is well on the fuse blowing.
On reassemble, it was found that the wipers only work on full speed and just stop wherever they are, they do not park. Also they do not come on with the screen wash. It is possible that some of the relays got mixed up during the diagnostic of the original problem. A second set of stalks was tried but made no difference.
Does anyone know which relay should be where in the fuse box or have any other suggestions that may help please.
Old 17-02-13, 03:44 PM   #2
I don't know where th relays are, but I'd certainly look at the state of them. My S2 fried the wiring to the tailgate and this in turn fried the rear wiper relay, so check any of the associated relays, they could all be in difficulty.
Old 17-02-13, 04:24 PM   #3
missfire
missfire's Avatar
I can take as many photos as you like of 100 fuse boxes and relay panels, but none have AC, so maybe not much good.
Old 17-02-13, 04:30 PM   #4
missfire
missfire's Avatar
This looks like the culprit maybe, decent photos down the page. The fusebox lid or the big label inside the parcel shelf under the steering wheel should tell you where to stick it!
http://www.ebay.co.uk/itm/VW-Audi-Se...-/270914110545
Old 17-02-13, 04:36 PM   #5
missfire
missfire's Avatar
Relay position 9 in the fuse box. from sjmautoteknikification.
Intermittent function control, but might affect other functions? Dunno.
Old 17-02-13, 04:56 PM   #6
baron2211
baron2211's Avatar
Cheers chaps. I've just come in from looking at it and now think that part of the problem may be the wiper motor is shot. I tested it off the car and it still wouldn't park in the correct place. I've found a replacement on eBay for 25 quid delivered, so thought that wasn't too bad and ordered it.
After a chat with my brother, he agrees and added that the intermittent relay may also be shot due to the testing and continuous fuse blowing while the fault was being found.
Thanks for the offer of pics Missfire, I'll give you a shout if I need any. I reckon that the lack of ac will only leave an empty space in the box!
I'll keep you posted with progress.
Old 20-02-13, 07:50 PM   #7
baron2211
baron2211's Avatar
Well the new wiper motor arrived in double quick time and... it is wrong! Arrrgggh!! . The wiring connector is an awful lot smaller than the one on the car's loom. So back to the drawing board and in the mean time no car.
Old 21-02-13, 04:40 AM   #8
I'm wondering - how did you tested your wiper motor off the car if you expected it to park? Of course it won't, as it contains 0 electronic parts which could do it. But since you have removed yours, you can open it, clean the contacts, scrape out old grease and grease it to be sure it will work as expected.
As for the goddamn relay - on fusebox cover should be schematic what should be in each place. If you still want to get another relay - find yourself relay number 99 - it's direct fit in old audis, but it additionally have programmable interval. Very often found in mk3 golf, got mine from one as well.
Old 28-02-13, 12:00 PM   #9
baron2211
baron2211's Avatar
Cheers for that MSH, I was told how to test it by my brother who is a tech with Ferrari, he was under the impression that the motor had a park switch in it, it dies have a permanent live, so this makes sense. We managed to establish that the wiring is ok to the motor.
Nearly 6 weeks off the road now, this is starting to get annoying.
Old 04-03-13, 05:42 PM   #10
baron2211
baron2211's Avatar
Finally, its sorted! The motor's connections were cleaned up and the gears regreased and some relays cleaned up too. Strangely, the headlamp washers now work too, the never did before; bonus!
