Classic Audi » Technical » Mech/Tech » Electrical problems » Fuel Pump relay for 200 5E
Old 28-02-13, 07:09 PM   #1
garry1
Default Fuel Pump relay for 200 5E
hello i have a 200 5E type 43
fuel pump would sometimes start and some times not till i moved the relay
when removing the fuel pump relay it snaped in two
so ordered one from gfs which they said would fit audi 200 from 1979 to 1988
when the part arrived the pin out was totaly wrong so sent it back for a refund
on the original relay the part number is 433-906-059
found another one on line
part number 3-300-300 says it fits audi 200 5e and porsch924 DME fuel pump relay
when i tried this it does not even switch the fuel pump on
any ideas
Old 28-02-13, 07:49 PM   #2
quattro777
Super Sleuth!
quattro777's Avatar
I had to buy two of them last year, ended up having to buy from a Porsche specialist.
Here you go.
924 1979-85 Fuel Pump Relay 433906059
Old 28-02-13, 07:57 PM   #3
jack1
i had the same prob with my 200 at xmas so removed the 1 from the cd ,,im sure the relay from a b2 90 fits the same,,,,have you done any more to the 200 garry ,,have not seen it since the pics coxy had on it
Old 28-02-13, 08:19 PM   #4
garry1
Here you go.
hello quatro 777 that is the same one i bought and does not work
hello jack1 got it welded and painted just getting it all back togeather was hopping to get it on the road for april its no the best paint job i have seen but will do for now
Old 28-02-13, 08:25 PM   #5
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Might help found in all these models...
Part number search
Search for part number
433-906-059 found in ...
Audi 80/90/Avant 1982 , 811, 812, 813, 814 CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, F >> 81-C-250 000
Audi 80/90/Avant 1983 , 811, 812, 813, 814 CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, F >> 81-C-250 000
Audi 80/90/Avant 1984 , 811, 812, 813, 814 CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, F >> 81-C-250 000
Audi Coupe 1981 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi Coupe 1982 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi Coupe 1983 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi Coupe 1984 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi Coupe 1985 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi Coupe 1986 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi Coupe 1987 , 85. CENTRAL ELECTRICS, RELAY, FUSE BOX, BRACKET - RELAY PLATE/FUSE BOX, CONTROL UNIT FOR SHIFT AND CONSUMPTION INDICATOR
Audi 80/90/Avant 1979 , 81. SWITCHES FOR SIDE, MAIN LIGHTS AND EMERGENCY LIGHTS, HEATED REAR WINDOW, FRONT AND REAR FOG LIGHTS, TAIL LIGHTS, ELECTRIC WINDOWS, REMOTE- CONTROLLED ELECTRICALLY HEATED MIRRORS
Audi 80/90/Avant 1980 , 81. SWITCHES FOR SIDE, MAIN LIGHTS AND EMERGENCY LIGHTS, HEATED REAR WINDOW, FRONT AND REAR FOG LIGHTS, TAIL LIGHTS, ELECTRIC WINDOWS, REMOTE- CONTROLLED ELECTRICALLY HEATED MIRRORS
Audi 80/90/Avant 1981 , 81. SWITCHES FOR SIDE, MAIN LIGHTS AND EMERGENCY LIGHTS, HEATED REAR WINDOW, FRONT AND REAR FOG LIGHTS, TAIL LIGHTS, ELECTRIC WINDOWS, REMOTE- CONTROLLED ELECTRICALLY HEATED MIRRORS
Audi 80/90/Avant 1977 , 82., 83., 84., 85., 33. SWITCH FOR SIDE, MAIN AND EMERGENCY LIGHTS, FUSE BOX/ RELAY PLATE, RELAYS
Audi 80/90/Avant 1978 , 82., 83., 84., 85., 33. SWITCH FOR SIDE, MAIN AND EMERGENCY LIGHTS, FUSE BOX/ RELAY PLATE, RELAYS
Audi 100/Avant 1982 , 43. FUEL LINE, FUEL PUMP, ACCUMULATOR, FUEL FILTER 2.2ltr.
5-cylinder
K-JETRONIC
Audi 100/Avant 1982 , 43. FUSE BOX, RELAY
Audi 100/Avant 1980 , 43. FUEL LINE, FUEL PUMP, ACCUMULATOR, FUEL FILTER, FUEL INJECTION ENGINE 2.2ltr.
5-cylinder
K-JETRONIC
Audi 100/Avant 1981 , 43. FUEL LINE, FUEL PUMP, ACCUMULATOR, FUEL FILTER, FUEL INJECTION ENGINE 2.2ltr.
5-cylinder
K-JETRONIC
Audi 100/Avant 1980 , 43. CENTRAL ELECTRICS, RELAY
Audi 100/Avant 1981 , 43. CENTRAL ELECTRICS, RELAY
Audi 100/Avant 1977 , 43. ACCUMULATOR, FUEL FILTER, FUEL PUMP, FUEL PIPE 5-cylinder
2.2ltr. K-JETRONIC
Audi 100/Avant 1978 , 43. ACCUMULATOR, FUEL FILTER, FUEL PUMP, FUEL PIPE 5-cylinder
2.2ltr. K-JETRONIC
Audi 100/Avant 1979 , 43. ACCUMULATOR, FUEL FILTER, FUEL PUMP, FUEL PIPE 5-cylinder
2.2ltr. K-JETRONIC
Audi 100/Avant 1977 , 43. SWITCHES FOR HALOGEN FOGLAMPS- REAR FOGLIGHTS, CRUISE CONTROL SYSTEM, HEATED REAR WINDOW AND AIR CONDITIONER
Audi 100/Avant 1978 , 43. SWITCHES FOR HALOGEN FOGLAMPS- REAR FOGLIGHTS, CRUISE CONTROL SYSTEM, HEATED REAR WINDOW AND AIR CONDITIONER
Audi 100/Avant 1979 , 43. SWITCHES FOR HALOGEN FOGLAMPS- REAR FOGLIGHTS, CRUISE CONTROL SYSTEM, HEATED REAR WINDOW AND AIR CONDITIONER
Audi 200 1980 , 437, 438 FUEL LINE, FUEL FILTER
Audi 200 1981 , 437, 438 FUEL LINE, FUEL FILTER
Audi 200 1982 , 437, 438 FUEL LINE, FUEL FILTER
Audi 200 1983 , 437, 438 FUEL LINE, FUEL FILTER
Audi 200 1980 , 437, 438 CENTRAL ELECTRICS, FUSE BOX, RELAY CARRIER, RELAYS
Audi 200 1981 , 437, 438 CENTRAL ELECTRICS, FUSE BOX, RELAY CARRIER, RELAYS
Audi 200 1982 , 437, 438 CENTRAL ELECTRICS, FUSE BOX, RELAY CARRIER, RELAYS
Audi 200 1983 , 437, 438 CENTRAL ELECTRICS, FUSE BOX, RELAY CARRIER, RELAYS
Old 28-02-13, 08:32 PM   #6
garry1
cheers audi derek
unsure why the replacement part number 3-300-300 wont switch the pump on when it says its the same
will have a go with it over the weekend and let you know how i get on
Old 28-02-13, 08:45 PM   #7
quattro777
Super Sleuth!
quattro777's Avatar
That's strange, worked in my 100 5E.
Old 28-02-13, 08:48 PM   #8
garry1
will take it to work with me tomorrow and get it checked out it could just be a faulty one i got
Old 01-03-13, 01:36 PM   #9
garry1
tested the relay 3-300-300 today and found out pins 15 and 31 are diferent ie swaped over inside the relay compared to the original audi part have made up leads to check this in the car
also if it works would have to removed the two wires from under the fuse box and swap them over
but dont know if this is the best way to go
just tried it and it worked car started first time but it stays on when the key is at position 1 when it should just prime and stop
