Classic Audi » Community » General Chat » Rejuvenating Ni-Cad batteries.
Old 04-02-12, 01:49 PM   #1
missfire
missfire's Avatar
Default Rejuvenating Ni-Cad batteries.
Anyone tried it? For a drill/driver/screw gun in this case.
There are various methods on the net involving mig welders.
Some say the packs will not recharge because certain cells will have polarity shifts..!? and you can jump them back into life with careful application of low duration high voltage pulses, kind of like what the Ctek chargers do?
What do'you think? Worth a try with a large face mask? I can't buy new ones as they are obsolete, the only other option is £300 on an equivalent srcew gun that will come with new batteries.
Old 04-02-12, 02:14 PM   #2
ChrisG
ChrisG's Avatar
What is the make/model?
I dismantled one of my Erbauer batteries recently, ( I believe NLA -- just like loads of Audi parts !! ) only to find out that inside the large black plastic case it had 10 ordinary C size NiCads, all soldered together with connector wire to form one 14.4 volt unit.
I know that 10 years ago the model aeroplane guys soldered these C batteries together, to get the correct voltage to power the motors in electric flight ( quiet! ) planes-- now we have Li ion and Li poly.
I believe that a number of the older Bosch 9.6 v drill drivers are the same , seven c cells.
Old 04-02-12, 02:21 PM   #3
LYT4X
Younger than JJ !
LYT4X's Avatar
First thing to note is that rechargable batteries of any chemistry don't last forever. Whether it's NiCads, NiMh's or Li-ion's they all have a lifespan beyond which they are basically junk. However, NiCads tend to be the ones which appear to be knackered soonest but can be brought back to serviceable life the easiest. The problem with NiCads is that they can suffer most from a build-up on the charge plates (like dental plaque) which prevents them from discharging properly. If this is your issue, the best way to rejuvinate them is a succession of complete charge/discharge cycles. We are not talking about one or two cycles here. More like six to ten cycles of complete charge then complete discharge. If you don't get any improvement past this, then they aren't going anywhere. I've no ideas what you could be doing with a mig welder but I can't see that helping much!
________
John
Old 04-02-12, 02:34 PM   #4
missfire
missfire's Avatar
Well I just gave it a go... on charge now. didn't blow up yet!
It's a pack with twelve 1.2V 1500mAH cells in it. You can buy them and solder them together indeed! Lets see how long the charge lasts under full load. I'll try the full discharge full charge cycle thing too!
It's the only gun I have that will drive 150mm timberfix screws, a big cheap massive hammer drill driver thing from B&Q, it's actually really well built surprisingly. I tried driving them with a little 12V Erbauer the last time I used them, it wasn't too happy about that.. it almost split the gun down the middle.
Old 04-02-12, 02:40 PM   #5
missfire
missfire's Avatar
What brand would you buy if you had to buy a new gun..????????? if money was no object, what is the best brand?
Old 04-02-12, 02:43 PM   #6
dgacampbell
dgacampbell's Avatar
Try here, i have used them before, it does mean splitting the battery pack, but it is the best cure, you will need super glue lol and maybe a soldering iron.
http://www.batteriesplus.co.uk/
dgacampbell is offline   Reply With Quote
Old 04-02-12, 02:45 PM   #7
missfire
missfire's Avatar
cheers! on favourites now!
Old 04-02-12, 02:48 PM   #8
Phil Payne
Banned
I have a Makita D3000 right-angle drill that I bought in 1985. Just recently the Hire Shop in Sheffield got me two new batteries from Makita for £23 each. The drill was older than any of the four shop assistants.
Old 04-02-12, 02:56 PM   #9
ChrisG
ChrisG's Avatar
trouble is I'm finding that a lot these days.
There's a lovely young lady in the local dealers - we have bit of a flirt etc etc trouble is she probably young enough to be my GRANDAUGHTER
Old 04-02-12, 03:19 PM   #10
missfire
missfire's Avatar
nothing wrong with that! as long as you're not related...
makita, deeeewalter.. any more? specialist screw guns that take collated screws there's more choice but i just need an all rounder gun... do makita and dewalt keep the same terminal set up on the battery packs for many years? that's my problem with this gun, they still make them... only they change the terminal set up every two years so that you need to buy a new gun every two years.. real crafty that is..
