Classic Audi » Technical » Mech/Tech » Suspension & Brakes » B3 quattro wheel bearing.
Old 21-03-13, 09:11 PM   #1
Default B3 quattro wheel bearing.
I'm in mid change of a front wheel bearing on my CQ:-
Took the hub carrier off the car.
Battered the hub(bit the wheel bolts to) from the bearing,drifted off the bit of the bearing race that was still on the hub.
So I'm left with the hub carrier with the main part of the bearing still attached, normally there's a corroded cir-clip to remove before drifting the old bearing out but this has what looks like a cir-clip but it has no start/finish and seems to be part of the hub?
How does the bearing come out? (still don't have a haynes manual!)....am I losing it?!
Thanks in advance,
Old 21-03-13, 09:58 PM   #2
http://files.inbox.lv/ticket/9a4bb69...df?language=en
Old 22-03-13, 06:06 AM   #3
MSH,
Thanks........but it's a quattro, the bit about front bearing replacement refers to removing cir-clip, mine doesn't seem to have a cir-clip.......it looks like part of the hub carrier would have to be broken to get the bearing out??
Old 22-03-13, 08:19 AM   #4
Have no idea, as I haven't changed any wheel bearing in my life yet, but I doubt there would be any differences in front suspension caused by different rear axle.
AFAIK wheel bearing is usually changed with hydraulic press.
Old 22-03-13, 09:20 AM   #5
Tun
Tun's Avatar
John, I had the same problem with mine (90 quattro 20v). I checked on vagcat and it showed no circlip even though it looked like you descibed, also there was no replacement circlip with the new bearing which was genuine audi. I pushed the bearing out with a fly press expecting trouble but it came straight with no problems! I think from memory that the bit I thought was a circlip was part of the cast of the hub. Also, from memory, I sure 10v cars have circlip I'm not sure which yours is.
1988 MB quattro
2012 S4 Avant
Old 22-03-13, 06:25 PM   #6
Originally Posted by Tun View Post
the bit I thought was a circlip was part of the cast of the hub.......... 10v cars have circlip I'm not sure which yours is.
That's what I'm talking about......so if I press it out I'll hopefully just break this bit from the casting....then press in the new bearing as is, so it'll be in place but with no circlip securing it.
Mines is a 20V.
Cheers Tun, what you've said makes sense.
Old 22-03-13, 07:17 PM   #7
Tun
Tun's Avatar
John it difficult to explain but the bearing just pressed out and nothing broke, the ridge was either part of the hub or bearing can't remember which but there was definitely nothing retaining the bearing.
Royston.
1988 MB quattro
2012 S4 Avant
Old 22-03-13, 07:38 PM   #8
....there was definitely nothing retaining the bearing.
Royston.
Going to go out to the garage and take a couple of pics..........please stay tuned!!
Old 22-03-13, 07:47 PM   #9
there's no circlip on the later B3 cars.
The bearings are tapered btw - make sure you refit the new bearing the right way round
1991 90 quattro
Old 22-03-13, 07:50 PM   #10
Forgot to add.
There's also a protective ring for the ABS sensor - that should just pull out
1991 90 quattro
