Classic Audi » Technical » Mech/Tech » Transmission » 01E into typ85
Old 14-09-08, 03:50 PM   #1
jogi730
jogi
jogi730's Avatar
Default 01E into typ85
I have finally bitten the bullet and bought myself an 01E six speed gearbox.
I know it's not a diect replacement.
Does anyone have the rundown of all the parts I need to acquire to complete this swap?
Many thanks
Chris
jogi730 is offline   Reply With Quote
Old 14-09-08, 04:03 PM   #2
s2rob
try the search,its been covered a couple of times......if your not a spanner man its not going to be easy!!i have done a couple of conversions now....check out s2forum
s2rob is offline   Reply With Quote
Old 14-09-08, 04:10 PM   #3
jogi730
jogi
jogi730's Avatar
Tried the search, but can't find anything.
Ideally do not want to go the 5 stud conversion
Cheers
Chris
Old 14-09-08, 04:21 PM   #4
s2rob
a 6speed linkage will be required,together with the gear lever(which will need modifying)unless you chop the raised section of the s2 tunnel and weld it in,the x member is different as the 6 speed mounting is in the wrong place(nearside only..offside should be same)ball joint sizes are different if you use 6 speed subframe.......you will be better off getting gearbox mounts made up to fit the origanal x member(or subframe)....clutch centre plate is different....only easy thing is it bolts to any 5 pot engine...good luck with the project...more info on quattro forum or s2 forum....i have been informed there will be an artcle about this conversion in audi driver mag
Old 14-09-08, 04:29 PM   #5
jogi730
jogi
jogi730's Avatar
Rob,
Thanks for the info. I may well go down the S2/ Audi coupe subframe route to help with roadholding issues (ie standars AARB's). I have changed my wishbones to cast ones from the standard pressed jobbies, so I am running S2 balljoints already.
WHat about drive shafts and the prop shaft?
ANy more innfo or links to this conversion would be most helpful and I will bviously keep my eye open for the article.
Cheers
Chris
Old 14-09-08, 04:34 PM   #6
s2rob
propshaft and front shafts should be direct fit....will try for some links..
New tyres and/or wheels for my Typ85 CQ S2 PTH Wheels & Tyres 6 24-10-15 09:24 PM
01E 6 speed into typ85 jogi730 Transmission 7 09-01-10 07:59 PM
Typ85 4 pot hub nut size pimpdriver Transmission 1 21-12-09 07:43 PM
Typ85 Coupe Puglife Cars Wanted 5 18-10-09 10:31 AM
