Classic Audi » Technical » Mech/Tech » Suspension & Brakes » So, you've been out......
Old 02-07-11, 04:58 PM   #1
MadderThanMax
MadderThanMax's Avatar
Default So, you've been out......
........ for a drive, your car has discs and pads all round - should there be any heat on the rear wheels (alloys) when you stop?
a/ Nil
b/ Slight Heat
c/ roasting
Discuss...
MadderThanMax is offline   Reply With Quote
Old 02-07-11, 05:01 PM   #2
rich.r
depends on how much/hard you have used your brakes
you will allways get heat soak
Old 02-07-11, 05:32 PM   #3
yes coz if you havent you aint trying hard enough
Old 02-07-11, 05:42 PM   #4
Couperman
Smut Meister
Couperman's Avatar
c. Roasting - if the brakes ain't hot you ain't driving it hard enough
Rod Inwood - Member 1467
Previously owned :-
Old 02-07-11, 05:42 PM   #5
Nil, assuming normal driving.(and your brakes are in correct working order, wheel bearings haven't collapsed and you've remembered to release the hand-brake !)
J.
Old 02-07-11, 06:23 PM   #6
Depends,if you leave your handbrake on?
KARL.
Old 02-07-11, 06:36 PM   #7
Phil Payne
Banned
The rears do 5% to less than 10% of the work. So compare them with the front and - more importantly - with each other.
Old 02-07-11, 06:40 PM   #8
yeti
I did that the other day, got to the bottom of the road and wonderred why the van stopped itself when I took my foot off the juice
In my defence, I'd been on nights.
2003 Cors-arrrgh
Old 02-07-11, 06:59 PM   #9
I did it,when I 1st started driving.
Wasn't fully on,one click.They didn't half,heat up.
KARL.
Old 02-07-11, 07:20 PM   #10
Andy Douglas
Andy Douglas's Avatar
If they are roasting could well be siezing up,common problem with rear discs due to under use.
No Audi at Present
MGF VVC
Honda CRV (daily wife bus)
Peugeot Expert (work van)
VW Polo 1.9 TDI No 1 sons 1st VAG car
Andy Douglas is offline   Reply With Quote
