Classic Audi » Technical » Mech/Tech » Transmission » Wr flywheel on aby
Old 18-06-11, 07:44 PM   #1
martinws
Default Wr flywheel on aby
I'm about to fit a wr flywheel and clutch to an aby. I think this is an obvious question but when I'm at TDC is the timing pin on flywheel infront of the crank sensor?
Cheers
Old 18-06-11, 09:39 PM   #2
Tonks4x4
Tonks4x4's Avatar
No it is not....
The flywheel will only actually bolt o. In one position anyway so you can't get it in the wrong position.
Look for the 0 on the flywheel rim that will indicate TDC once the gearbox is fitted you can see half of it through the viewing window
http://www.tonks4x4.com
Old 18-06-11, 09:45 PM   #3
Originally Posted by Tonks4x4 View Post
No it is not....
As above, pick your clutch and power output carefully though....
Old 18-06-11, 09:48 PM   #4
martinws
Nice on tonks.I was just sitting watching tv and it suddenly popped onto my head, I changed front crank seal,water pump etc today and was going on to the rest in the morning.
Old 18-06-11, 09:49 PM   #5
Tonks4x4
Tonks4x4's Avatar
Should be running tomorrow night then
Old 18-06-11, 09:50 PM   #6
KARL.
Old 18-06-11, 10:07 PM   #7
martinws
That will be the day.haha. The mechanical side doesn't bother me, just the wiring.
Isimmo- iv got a new wr clutch to use, Engine is staying standard for now.
Old 18-06-11, 10:21 PM   #8
That'll be good... we are running circa 300bhp on an uprated WR clutch with the AAN and I'm told that's about all it'll take + or - ... Certainly not had any problems so far, but I'm relatively gentle with it, although....
It does get a little abuse occasionally....
Old 19-06-11, 04:54 PM   #9
martinws
Just fitted timing belt with new pulleys, rear crank seal, pressed bearing into rear of crank and put on the flywheel. I see what you mean by all the holes only lining up in one position. Dinner then ill move onto the clutch.
