Members: 19,823 | Total Threads: 40,097 | Total Posts: 471,134 Currently Active Users: 7388 (1 members and 7387 guests) Welcome to our newest member, BuddyInons |
Ragtop Collector
As above can anyone advise what the symptoms are for a failed knock sensor?
I am trying to get this pig of a Cab sorted and it was mentioned that it could be the knock sensor. Ta Andy |
Engine?
Problems? |
Ragtop Collector
Yes would help wouldnt it..... ![]() 2.3 10V (NG) Its a running saga but....... ![]()
I had a knock sensor fail on my 90 20v.
It would misfire at about 4k and feel like it was holding back the power. Once you got to 4500rpm, it would take off again. it made overtaking quite entertaining
Sounds more like usual problems with KE-jetronic
Dead knock sensor would mean detonation, especially when driving around town using throttle enough and backfire when turning off engine, maybe some "dead spots" at low rev range, but negligible impact on fuel economy and very small on performance. Long time ago I had 3A with dead knock sensor, I came to conclusion that that KE-Motronic can't provide proper ignition without it. While driving without it, I had adjusted a bit later ignition, so it didn't detonated while driven on road [as was most of my usual route], but when I got new knock sensor and readjusted ignition, max speed increase was 30 kmph ![]() |
Are you changing that stuff or someone else for you? I have a couple of recommendations what you could check, but it requires some tools and pair of straight [not curve
] hands ![]() |
Ragtop Collector
First thing to check, I think, should be cold start injector, because it's the least difficult part of all
Disconnect connector, undo both bolts, remove it, point it away, close that hole in manifold with your finger or something else that won't be sucked in manifold and ask someone to start engine. If injector is squirting fuel, you have found fault. But actually before that you can try to disconnect air mass meter potentiometer and pressure regulator - one at once. When everything's fine, disconnected potentiometer should only make strange, fluctuating idle but nothing more, while disconnected pressure regulator should decrease performance, probably some starting issues and it also removes redline ![]() |
#10 | |
dunno if its the same cause though. you never know... well, at least i never know...![]() |
