Classic Audi » Technical » Car detailing & polishing » Clay
Old 04-06-08, 10:55 AM   #1
Default Clay
Do you polish before or after you have used a clay bar?
Old 04-06-08, 11:46 AM   #2
after.
First, wash, then clay, then polish.
Be careful when claying, use loads of lubricatant (even if it's just water) and only rub over the paint lightly. Too much pressure and you will marr the paint.
Old 04-06-08, 01:04 PM   #3
Ok thanks Coxy I will be gentle
Old 04-06-08, 01:06 PM   #4
the best way to describe it is to caress it like you would a womans body!
Old 04-06-08, 01:20 PM   #5
I don't do women
Old 04-06-08, 03:03 PM   #6
Ben
*chuckles*
Old 04-06-08, 03:37 PM   #7
another little bit of advice...use tar and glue remover first as well before you use the clay else you end up getting loads of tar spots on your clay bar!
Old 04-06-08, 04:39 PM   #8
pixsaudisex2
some women like it ruff though ( well the ones i end up with do )
pixsaudisex2 is offline   Reply With Quote
Old 04-06-08, 06:18 PM   #9
SteveCat
SteveCat's Avatar
Default .
Well,the ones I end up with like men AND women.Nerrrrrrr!
The Bilt Hamber clay requires just water as a lube.
I used Megs clay bar and Quick Detailer as the lube.
Not that I know any more than The Coxster,Im just being picky!
If you can find a Halfrauds that still sells Megs,they do a kit with it all in,and a microfibre cloth for £22.
Mercedes E220 Sportline Coupe
Old 04-06-08, 06:36 PM   #10
That's the one i have got
Meguiar's clay kit BIGGYIN Car detailing & polishing 22 02-10-09 06:13 PM
