Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,131 Currently Active Users: 5553 (2 members and 5551 guests) Welcome to our newest member, BuddyInons |
I'm about to fit a wr flywheel and clutch to an aby. I think this is an obvious question but when I'm at TDC is the timing pin on flywheel infront of the crank sensor?
Cheers |
No it is not....
The flywheel will only actually bolt o. In one position anyway so you can't get it in the wrong position. Look for the 0 on the flywheel rim that will indicate TDC once the gearbox is fitted you can see half of it through the viewing window
http://www.tonks4x4.com |
As above, pick your clutch and power output carefully though....
Nice on tonks.I was just sitting watching tv and it suddenly popped onto my head, I changed front crank seal,water pump etc today and was going on to the rest in the morning.
Should be running tomorrow night then
That will be the day.haha. The mechanical side doesn't bother me, just the wiring.
Isimmo- iv got a new wr clutch to use, Engine is staying standard for now. |
#8 | |
![]() It does get a little abuse occasionally.... ![]()
Just fitted timing belt with new pulleys, rear crank seal, pressed bearing into rear of crank and put on the flywheel. I see what you mean by all the holes only lining up in one position. Dinner then ill move onto the clutch.
