Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,133 Currently Active Users: 4072 (0 members and 4072 guests) Welcome to our newest member, BuddyInons |
anyone know what gearboxs (5 spd) are fitted to the FWD
b2 80's? what are the codes and is there a differance between the 5 spd fitted to the 80 sport models? differant ratios maybe? |
Cue BigT80... Pm him.
I know the gearbox fitted to the 1.8 DZ engined coupe GT is longer geared than the 80Sport DZ gearbox.... |
thanks for that. so my g/box is 013 type as its fitted to a 1.8 carb? how will i find out which code letters go with it, are they stamped on the box?
Can you find the sticker in the boot lid??? It will say something like "DS/gearbox code". DS is your engine code I think. The one in mine was something like DT/1Y I think
If you did not find the sticker in the boot lid, you will find it top of the gearbox, near to engine. It's usually dirty and/or oily.
#7 | |
![]() I've long thought that the Sports could easily pull a slightly higher gear....especially if they have been bored to 1.9 and/or headwork etc |
im actually trying to find a gearbox to match up to the 1.8t im installing next year
not sure if the standard little box will cope with 200ish bhp so im looking for options |
#9 | |
With standard clutch and without launch control no problems - that's experience of one known ppl. U probably will not have such problem anyway - because u don't have quattro, so excess power will turn one of front wheels into smoke There is no need for u to install other B2 gearbox except for longer fifth gear. If u want get rid of clutch cable and speedo cable than maybe some B3 gearbox, but I'm not 100% sure how much work is involved to fit B3 gearbox Although - that would mean gears would flip in different positions. Damn. ![]() |
the B2 80 GL gearbox has higher gearing, I'd be tempted to try it and see...... if you break it then maybe look at others ( B3 2.2 box ?? )
| Engine codes? | PhilGee | Engine | 6 | 20-08-09 07:35 PM |
| Paint Codes | ChrisG | Bodywork, glass & exterior fitments | 3 | 10-07-09 08:11 AM |
| Fault codes | vag80 | Engine | 2 | 12-01-09 02:24 PM |
| VAG Paint Codes | Coxy | Technical Info | 2 | 06-01-09 10:26 PM |
| paint codes | Micky | Technical Info | 8 | 26-10-08 08:03 PM |
