Members: 19,823 | Total Threads: 40,098 | Total Posts: 471,142 Currently Active Users: 8683 (1 members and 8682 guests) Welcome to our newest member, BuddyInons |
dunno if this is the right section to post this, but i want to know the flow rates and other related information(volume etc) of various inlet manifolds.
I was hoping someone might have a list of flow rates for comparison purposes. ![]() I think 4v6 had some info in this area? But I guess the two manifolds I really want to compare are the 10 valve turbo inlet manifold (was there only one design?) verses the naturally aspirated KV inlet manifold. |
Hi Gaz, got your pm.
Ok, i presume youre interested in knowing how much the intake manifold flows at the throttle body? Id need to do a blow through test on both types of intake and see what happened. From some of the tests i did on Emjays carbed intake iirc, i found the turbo intake flowed not much better than the carbed manifold. I do have a turbo intake i can test but i dont have a KV version. Ill run a flow test on the turbo item shortly (discharging thru all the ports) so we'll get a total flow figure for the manifold. Flow distribution will definitely be different for the KV item id say as it flows in from the other end. |
| 7a inlet elbow | audicoupeparts | Parts Wanted | 3 | 05-12-09 11:44 PM |
| WN carb inlet manifold | knobstar | Parts Wanted | 5 | 29-12-08 04:46 PM |
| New Vehicle Excise Duty Rates | Coxy | General Chat | 9 | 29-11-08 10:20 AM |
| Inlet manifold. | Booty | Engine | 4 | 05-09-08 06:16 PM |
| Jetronic Fuel Metering Head / Air Flow Meter | randall977 | Parts Wanted | 5 | 17-12-07 04:26 PM |
