Classic Audi » Classifieds section » Parts Wanted » 10v turbo clutch
Old 26-10-09, 08:53 PM   #1
8690q
8690q's Avatar
Default 10v turbo clutch
Hi,
I'm dropping the kv engine from my 1986 90 quattro and replacing it with a 7a engine from a later 90.
I'm sticking with the original gearbox which wont take the 7a flywheel and clutch.
I've already sourced the required flywheel, from a 10v turbo ( thanks quattrokid ) now I'm after a clutch to match this.
The kv clutch is far too small and the 7a clutch is only slightly to large in diameter. Sorry I don't have measurements, the clutches aren't to hand just now.
According to Eurocarparts it's a 240mm clutch I need for 10v turbo wr. 230mm for kv and 240mm for 7a.
I cant get the pressure plate to line up with the locators on the 10v turbo flywheel with the 240mm clutch I have.
I'm needing the friction plate ? and the pressure plate ? but not the bearing as the one off the kv is used.
Any help will be much appreciated.
Thanks.
Michael Williams.
8690q is offline   Reply With Quote
Old 27-10-09, 08:07 AM   #2
20vcqdriver
20vcqdriver's Avatar
Whats the problem! Did this conversion myself and fitted it to the old Cq gearbox with only a change to the 7A flywheel, removing the bearing and fitting a needle bearing instead. Have all articles on this swap if you would like them. Let me have your e-mail address in PM.
Clutch cable Audi Derek Transmission 0 26-07-09 06:50 PM
What Clutch to use with 7A quattropower Transmission 2 20-03-09 09:47 AM
Clutch problem joe90 Transmission 5 08-01-09 05:53 PM
Audi 100 2.8 clutch joe90 Transmission 0 11-10-08 03:22 PM
Clutch on GT5S knobstar Transmission 6 03-12-07 02:05 PM
