Classic Audi » Classifieds section » Parts Wanted » Electric Aerial PCB Relay
Old 03-07-09, 12:19 PM   #1
Steve
Steve's Avatar
Default Electric Aerial PCB Relay
Decided to raise some cash and part with some items that I've had for a while. Unfortunately one of the more expensive and desirable parts is not working anymore.
What I need is one of the open type relays as one of mine is open circuit. The part number is V23133 A1001 A503. You will be able to see this on the side of the relay.
Please PM if you have a spare or a complete PCB that I can take parts off.
Steve is offline   Reply With Quote
Old 03-07-09, 12:29 PM   #2
4v6
Try Maplins, Farnells or RS components, they may have a replacement.
Old 03-07-09, 02:01 PM   #3
Steve
Steve's Avatar
Already checked. There are a few companies in America that have stock, but minimum order is between $250 to $300 USD.
Old 03-07-09, 02:05 PM   #4
will check tonight Mr Broon....thanks for sorting the leather out too, looks spiffing
can i have a short back and sides next time?
Old 03-07-09, 02:37 PM   #5
4v6
Other alternative if its the relay coil thats shot is to strip the relay bare, remove the coil assembly and rewind it.
Wouldnt take long if you have the wire available.
Been there, done that.
Old 03-07-09, 03:45 PM   #6
Steve
Steve's Avatar
Find me that PCB Mr JJ and you can have what ever hair cut you want,....................... just don't ask me to trim your bush !
Old 03-07-09, 03:48 PM   #7
Steve
Steve's Avatar
It's on my agenda if I can't get sorted. The original problem was that there had been some corrosion which had fused to the coil and the earting plate. When this was cleaned off some of the copper wire broke away. I did think about soldering over, but would rather try and get the replacement part first.
Cheers for the ideas.
Old 03-07-09, 04:23 PM   #8
Basin cut ??
Old 03-07-09, 05:29 PM   #9
I have been into the garage, dodged the samba and I have a pcb you may have it faggott!
Old 03-07-09, 05:46 PM   #10
Steve
Steve's Avatar
Basin cut ??
You'll have to bring your own bowl as I haven't got one big enough for your heed.
Still got the Samba ?
'Faggott', how dare you........after all the soapy c***s you've had in your hands over the years.
Electric Aerial. Booty Parts For Sale 3 10-05-09 08:06 PM
Ur aerial parts stuartmmcfc Parts Wanted 0 02-05-09 03:32 PM
Coupe/Quattro Fuba Electric Aerial 86audicoupe Parts For Sale 1 28-03-09 02:38 PM
pneumatic aerial? Gaz In-Car entertainment 2 13-12-08 09:38 PM
Electric window relay Coxy Parts Wanted 0 28-07-07 05:02 PM
