Classic Audi » Technical » Mech/Tech » Engine » GT5S / GT Fuel Injection differences
Old 26-12-14, 06:46 PM   #1
yeti
Default GT5S / GT Fuel Injection differences
On closer examination, the 2144cc K-Jet engine in my Coupe is tired in a big way. I've been offered a carbed engine out of a GT5S, is there much difference between the short engines or is it just the manifold?
2003 Cors-arrrgh
Old 26-12-14, 08:02 PM   #2
20vcqdriver
20vcqdriver's Avatar
Carbed engine is normally a 1921cc, there was a carbed 2144cc in the audi 100 of the day if memory serves me correctly. Ifyour car is already fuel injected though, best to keep it that way as quite a few differences including the fuel tank.....
Old 27-12-14, 12:39 PM   #3
yeti
Ahaaaa, cheers for that. The plan was to put the injection onto the carbed short engine, but if it's a 1921cc, I'll bin the whole idea off.
2003 Cors-arrrgh
Old 27-12-14, 12:58 PM   #4
From memory, the bore is 79.5 on the WN and 81 on the KE. The rest of the capacity increase is from the throw of the crank. (Stroke).
Old 27-12-14, 09:15 PM   #5
Don't worry about displacement - if you want to use fuel injection, you would try to use bottom end only anyway - as there would be no place to fit injectors.
However, there's one interesting thing in that ancient 1.9 engine - I've heard that there's the most aggressive stock camshaft found on 5 pot engine - the only problem is that there's shims, not tappets, so head which receives that cam should have shims too.
Old 20-01-15, 12:29 PM   #6
PoloGaz
PoloGaz's Avatar
Still got the 2.0L 5 cylinder engine here Steve.
PoloGaz is offline   Reply With Quote
