Classic Audi » Technical » Mech/Tech » Engine » Audi 100 89G revs dropping when downshifting
Old 29-12-07, 10:07 AM   #1
Default Audi 100 89G revs dropping when downshifting
Hi,
I have a 89G 100 quattro with the NF engine (2309cc).
From cold, and when warmed up too, when I put the clutch down to change gear, the revs drop to 600rpm, and then stabilise at 800-820 ish. Very occasionally it will stall as the revs drop too far.
Also, the power steering gets heavier as the pump isn't being driven I guess.
Any ideas?
Steve
Old 04-01-08, 03:38 PM   #2
here is a video of the revcounter.
revs drop to 600
Old 04-01-08, 03:56 PM   #3
Is it just on cold or when she gets warm?
I had a similar thing on both my old 90 quattro and B3 Coupe 2.2 10v, but it was only when it was cold. the 90q seemed to almost stall momentarily a few times from cold start. I did post up a thread about this somewhere else about 12 months ago and I think the answer pointed to a few possibilities, one being the Air Flow meter, which more often than not, seems to be the root of many problems.
Old 04-01-08, 04:04 PM   #4
Where do you plug VAG-COM in on this car (ONLY JOKING!)
I've put it on Audifans too. My car may be too new! (once again, only joking). I consider this car to be a classic Audi, as it originally came out in 1982. I had the later 100 (J reg) but that is styled like a newer car.
However, it has the 5 pot engine.
Who thinks the best Audis were 80s cars? I would say this 89G 100 is more solid than our old 99V A4 avant......
Old 04-01-08, 11:00 PM   #5
think it might be the idle stab valve...... same problem on my 2.3 100 J plate......
Old 13-01-08, 01:15 PM   #6
cleaned the idle stabilisation valve today, problem sorted. Now idles at 800 rpm.
Turbo Diesel revs redline,can,t stop engine without stalling it??? BIGGYIN Engine 9 01-12-09 07:20 AM
Dropping a valve @ 20k!? Gaz Engine 5 10-01-09 11:05 PM
