Classic Audi » Technical » Mech/Tech » Engine » 1B Engine (same as MB ur quattro)
Old 22-04-09, 09:21 PM   #1
steveb
steveb's Avatar
Default 1B Engine (same as MB ur quattro)
Does anyone know what the oil pressure should be hot and cold, ie at idle & reving at say 3,000rpm (max & min) ?
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 22-04-09, 09:30 PM   #2
BW2309
Oil pressure min with hot engine at 2000rpm is 1.6bar. That's min tho, a good engine should be giving around 3bar lowest at 2000, upto 4+ higher up. Unless totally knackered, the oil pressure at cold start will be off the guage, over 5bar. This is due to the thickness of the oil when cold. At idle when warm you should have around 1.5bar - 2bar if the engines in good nick. If oil temp over 130degrees, like after a run, it may drop to just over 1.2 ish.
Old 22-04-09, 09:37 PM   #3
steveb
steveb's Avatar
Cold i have 4 bar at idle and over 5.5 reving
Hot , fan cutting in 1.3 at idle 3 reving
The problem is it is alarming for high oil pressure, i have tried new switches, even disconnecting them all dosen't stop the alarm (or connecting them to earth) The pressure relief valve is free as well, new oil and filter
[FONT]
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
Old 22-04-09, 09:47 PM   #4
BW2309
Do you have access to a spare dash pod you could try in it? The circuit inside can fail causing this fault. If you've not got one, don't go buy one. I can find the wiring diagrams for you so you can test the whole system to be certain before you spend any money!
Old 22-04-09, 10:04 PM   #5
steveb
steveb's Avatar
Brother has another 1B quattro will have get him to "borrow it back from his soon to be x wife
[FONT]
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
Old 22-04-09, 10:06 PM   #6
BW2309
Give it a try mate. Its quick n easy. If it still happens with new dash in by all means PM me, I'd be happy to help and supply information/wiring diagrams.
WR UR quattro engine + components Puglife Parts For Sale 5 03-07-17 05:36 AM
kv quattro engine mounts audicoupeparts Parts Wanted 0 29-06-09 08:26 PM
kv engine and other quattro stuff audicoupeparts Parts For Sale 1 11-06-09 09:32 AM
UR quattro ecu (for wr engine) for sale. Jenks Parts For Sale 1 15-02-09 03:14 PM
coupe quattro 2.2 KV engine Derek Engine 4 02-02-09 10:27 AM
