Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,120 Currently Active Users: 2353 (1 members and 2352 guests) Welcome to our newest member, BuddyInons |
Hi, I have been having problems fitting a timing belt to my 7A 20v engine that I am rebuilding,
I have fitted dozens of timing belts to Audi 5 cylinder engines in the past 26 years, but this one just didn't feel right, even got a second new timing belt to make sure that there was a problem with the first one, but today solved the problem, when stripping the old engine that I never had running the idler pulley bearing was noisy so measured it (74mm) and ordered it and fitted it when fitting new oil pump when it came to fitting the timing belt with the flywheel on '0' and the cams on '0' you need to fit the belt clockwise round the crankshaft pulley then anti-clockwise round the idler pulley the clockwise round the camshaft pulley and the timing belt teeth should fit into the camshaft pulley with no slackness in the belt, any slack should be on the water pump side where you adjust the tension via the water pump but the timing was 1/2 a tooth out with both of the belts, so after a minute of thought today my solution was to fit a 68mm idler pulley and hay-presto the timing belt fitted into the camshaft pulley with no problem, so, still had the old bits from the engine in a box and measured the old noisy pulley again and is was indeed 74mm, just thought I would post this for information. |
7A is supposed to have the 74mm pulley
Interesting? While it was a few years ago since I did the belt on my car, I'm wondering if the water pump only fits one way.....and would it be possible to fit it differently causing the timing issue?
I wish I had the room for "an engine room"!! Maybe one day. |
Thanks for the reply's, this may sound daft but this may turn out to be an oil pump problem, I will need to remove the timing covers from the other engines in the garage to have a look see at the size of the idler pulley.
