Classic Audi » Technical » Mech/Tech » Engine » Miss fire and cutting out
Old 29-10-16, 07:56 PM   #1
Bandycoot
Default Miss fire and cutting out
The other day I changed my cam cover gasket. Not a huge job but now there is a very irregular miss fire and it will cut out for a split second. It is worse when the cafe is up to temperature. I've checked the timing and that is spot on. The plugs and ht leads are just a few weeks old and fine. I've checked all the connections of all the bits I had to disconnect and all seams OK. The throttle body is clean. My thoughts vould be leaning towards a fuel problem. Any thoughts from you guys?
Bandycoot is offline   Reply With Quote
Old 29-10-16, 07:57 PM   #2
Bandycoot
It's a 90q 7A engine by the way.
Old 29-10-16, 09:07 PM   #3
Colin Aitchison
Colin Aitchison's Avatar
This would be a stab in the dark of night, just give us a clue may be model and cc and if you can engine number.
Old 29-10-16, 09:29 PM   #4
if it's an ignition cut, check the inlet manifold grounds and that the MAF connector is fully plugged in
1991 90 quattro
Old 30-10-16, 04:02 PM   #5
Bandycoot
Sorted. I was the manifold earth connections. I had somehow only connected one and the other as making an intermittent contact on the manifold. Hence the missfire.
Old 30-10-16, 09:44 PM   #6
sinbin5t
sinbin5t's Avatar
My kind of trick
