Classic Audi » Technical » Mech/Tech » Engine » Temperature guage fault.
Old 25-01-16, 12:01 PM   #1
Jake Blight
Jake Blight's Avatar
Default Temperature guage fault.
Flushed the radiator and replaced anything that needed replacing. Now the temperature gauge keeps shooting up even when cold. Any thoughts? Engine runs fine, pipes warm nicely, no apparent cold spots or air locks. I think its the temperature sensor/ sender (brass and white thing pictured). Not keen on forking out almost £30 just on a hunch.. Quattro Corner has a sensor on standby for me but I thought I would ask you lot first to see if anyone has had something similar happen.
No leaks, it's not overheating and drives fine.. I am stumped.
Jake Blight is offline   Reply With Quote
Old 25-01-16, 01:05 PM   #2
what happens if you disconnect - I'm guessing it will fall to zero
Gauge going off the scale is usually achieved by earthing the signal wire for the gauge.
You can check for a short on the 2 wires and also across the terminals on the sender.
1991 90 quattro
Old 25-01-16, 01:25 PM   #3
Duffy3074
I thought the one for the gauge was the one on the underside of that elbow?
Old 25-01-16, 02:54 PM   #4
Mellis46
Aero Advocate
Mellis46's Avatar
The single one underneath (on the kv at least) is the coolant temperature sensor, plenty of fun and games it causes too with lack of cold start or funny idle speed when it begins to mis-behave...!
Old 25-01-16, 04:50 PM   #5
Jake Blight
Food for thought there.. Thanks for the heads up.. Alas can't look at it for another few days so will have to fret about it until then. i so get 'tetchy' when silly stuff goes wrong..
Old 25-01-16, 04:52 PM   #6
sinbin5t
sinbin5t's Avatar
[quote=Jake Blight;39828 Alas can't look at it for another few days so will have to fret about it until then. i so get 'tetchy' when silly stuff goes wrong.. [/QUOTE]
Yep know that feeling well
Old 25-01-16, 05:45 PM   #7
M4rkp
M4rkp's Avatar
out of interest - what engine code are you?
If it keeps shooting up randomly, then disconnect the sender, if it carries on shooting up then you have a short ( to ground) in your harness - if it stays at the bottom, you have a sender issue.
I recently had the reverse of your problem - no temp gauge at all - changed sender - twice - still no gauge.......it turned out that i had lost electrical continuity between the block and the water outlet!
Mark
M4rkp is offline   Reply With Quote
Old 25-01-16, 06:19 PM   #8
Colin Aitchison
Colin Aitchison's Avatar
On my 1987 B2 Coupe GT the one on top with two terminals is for the engine temp gauge the one on the bottom with one wire is for the ISV, if you would like I could go and measure the resistance across the terminals of the top sender when cold and see if you get close to the same if not a similar ohms reading I would say it is the sender.
Old 25-01-16, 06:29 PM   #9
Colin Aitchison
just had a look on www.partsbase.org the part number for my coupe 2.2 GT is 049919501B copy and paste this in to ebay and there are two under £9. This part is fitted to many Audi/VW engines, also if you remove the two pin plug from the sender dose the gauge drop to cold, if not it is a wiring problem, if it dose it is the sender. Hope this helps.
Old 25-01-16, 06:52 PM   #10
Jake Blight
If it keeps shooting up randomly, then disconnect the sender, if it carries on shooting up then you have a short ( to ground) in your harness - if it stays at the bottom, you have a sender issue. I recently had the reverse of your problem - no temp gauge at all - changed sender - twice - still no gauge.......it turned out that i had lost electrical continuity between the block and the water outlet!
Mark
My cq is using the KV engine. Thanks for the above.. useful.
