Classic Audi » Classifieds section » Parts Wanted » Braided fuel injector pipes for Cq KV '87
Old 03-10-15, 05:05 PM   #1
Leg2562
Leg2562's Avatar
Default Braided fuel injector pipes for Cq KV '87
Anyone have a set of 5 of the braided fuel injector pipes for a Cq? Two of mine have corroded right through and are seeping fuel. Only a matter of time before it turns into a drip and then I'll be driving around in a fire hazard
Gone fully electric.
Has beens: 1987 Coupe quattro, 1983 80 GL, 1985 Coupe GT, 1984 80 Sport
Leg2562 is offline   Reply With Quote
Old 03-10-15, 07:20 PM   #2
quattrostyle
There is difference in thread pitch on the injector end of the braided fuel lines. I have had injectors/lines with fine pitch and 'normal' pitch. Be sure you get the correct ones.
Old 03-10-15, 07:26 PM   #3
audicoupeparts
Typical! I sold my last set earlier in the week!
Old 10-10-15, 08:09 PM   #4
farmer phil
farmer phil's Avatar
May have a set ,not sure of condition as they are still on the engine .
farmer phil is offline   Reply With Quote
Old 10-10-15, 10:55 PM   #5
audizzz
Had mine made to match by Earls of Silverstone cost me £100. New ends and braided.
They are pretty close to you and if I remember correctly took 24 hours. They did need the old ones to match up.
audizzz is offline   Reply With Quote
Old 11-10-15, 11:20 AM   #6
Leg2562
Leg2562's Avatar
Thanks.Are they the same type as in the above picture? ie. Braid changing to solid metal pipe? Some have braid all the way through and I'm not sure if they will fit or not.
Old 11-10-15, 11:21 AM   #7
Leg2562
Leg2562's Avatar
Thanks. I will bear them in mind if my search for a second hand set fails.
Old 11-10-15, 11:50 AM   #8
audicoupeparts
Look similar to ng set I took off yestetday
Old 11-10-15, 04:43 PM   #9
audizzz
Found the link plus a piccie.
Parts wanted:- audi 90, 2-1-15. there is a picture on there. As I said they need the old ones to make new copies of the ends and length.
They make the lines for the formula 1 cars on the track, so excellent service.
Old 22-11-15, 12:49 PM   #10
https://www.gumtree.com/p/car-replac...es-/1143290178
Maybe of use?
