Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,121 Currently Active Users: 5390 (0 members and 5390 guests) Welcome to our newest member, BuddyInons |
Is there anything common on the 2.3 NG that causes bad starting? I've just rought the car as a project so service wise I'm changing everything like plugs, dizzy cap, rotor arm etc.
It spins over for ages before it half heartedly fires, and once its going its lumpy, give it any throttle and it seems to cut out as if it's over-fuelling! |
Idle Stabilization Valve maybe?
Why is it always oxygen sensor or ISV that gets blamed?
![]() I'll bet it's receiving not enough fuel, not too much. If in doubt, when it stalls, remove spark plug and check if it's wet. What's the idle speed when warm and does rev limiter kicks in @ 6,8k? |
I'll have a check! After idling a bit rough for a minute it does clear, run and idle fine!
Does the NG still have a cold start injector? If it does, try unplugging it. (blue plug on manifold) If engine starts better then you have leaky main injectors adding fuel to the cylinders when the engine is off.
It sounds a lot like how my 2.0 10v engine was running. Cranks for maybe 10-15 seconds then fires and runs like sh1t. But leave it for a week and it would fire immediately - all the fuel that leaked into the cylinders had evaporated. You still got the B3 TDI as well? ![]() Last edited by PoloGaz; 05-09-14 at 08:55 AM. |
How unplugging CSV removes fuel that has lowered compression in a cylinder?
Of course there is CSV - all KE-jet engines have it. |
I dont understand your question.
Could be as simple as an air leak?
Did you ever figure out the problem mine dose the same thing.
