Classic Audi » Technical » Mech/Tech » Engine » engine mount
Old 18-04-15, 09:27 PM   #1
paraglider
Default engine mount
can anyone help; i notice the front engine mount on my '89 b3 coupe is not captivated in any surround just the rubber protrudes towards the front cross member with fresh air of several m/m all around,there is a flange with 2 mounting bolts in front of it ,suggesting somethings missing could it have rotted off? the car is still silky smooth ,so its surprising.
paraglider is offline   Reply With Quote
Old 18-04-15, 09:47 PM   #2
Mellis46
Aero Advocate
Mellis46's Avatar
I'm sure I'll be immediately corrected if I am wrong but think this is how its supposed to be. The bulk of the work is done by the other mounts this front one is more of a "bump stop" for any forward movement from the engine. I saw a few years ago when buying suspension bushes polyurethane replacements are available if it is worn out but havent come across the need on either my current or previous b3 90s...
Old 23-04-15, 08:39 PM   #3
paraglider
thanks that sounds likely,& reassuring.
Old 23-04-15, 08:46 PM   #4
Hanuman
Hanuman's Avatar
Items 20 - 27, it's not a mount, it's described as a limit/stop
Sent from my iPad using Tapatalk
Old 23-04-15, 10:26 PM   #5
Andy10v
Andy10v's Avatar
It stops the front of the engine rising under acceleration.
I welded a bit of short pipe onto my crossmember for a 360* snub mount to stop it diving under engine braking, like a sport quattro one.
2005 350z GT
Sold-1993 ABY coupe
Old 24-04-15, 09:07 AM   #6
PoloGaz
PoloGaz's Avatar
B2s also have a 360° mount like that, at least that's what i found in my Passat...
PoloGaz is offline   Reply With Quote
Old 24-04-15, 01:29 PM   #7
spink
must be only on the vw versions of the b2,odd the 90s/gts etc didnt get it
it is only about £12 to buy that piece,or was at least a few years back
Old 24-04-15, 01:55 PM   #8
PoloGaz
PoloGaz's Avatar
Just had a look on vagcat, the part number is 331199311. so does appear to be a passat only item!
holes look very offset in the image, in reality they are slotted and start more or less level with the centreline of the hole the rubber bush sits in.
