Classic Audi » Technical » Mech/Tech » Transmission » 1.8t running but the clutch isnt man enough HELP
Old 06-08-13, 01:32 PM   #1
BryFlyinBy
BryFlyinBy's Avatar
Default 1.8t running but the clutch isnt man enough HELP
Hello Friends
Got my car running, now converted to 1.8t with the Garrettt Gt28rs turbo.
It runs well and produces lots of power (un-measured yet) my big problem -the cheap clutch I bought from TechniClutch - a so-say uprated package with Single Mass Flywheel slips at the nearest whiff of Boost.
I'm trying to get my head around what I need with out forking out loadsof money I havent got!
My first issue is people ask what gearbox I have - and I dont know the code it came from a 2.3 20v B3 coupe 1990/91 model
Please can someone tell me the code and also possible a good combination of clutch parts to buy to accept potentially 300bhp.....potentially.
Also it would be really good to know if the lightened fly wheel purchased as part of the kit will work with say a Sachs SRE type friction plate and cover.
Thanks in advance
Bry
BryFlyinBy is offline   Reply With Quote
Old 06-08-13, 04:27 PM   #2
FWD or quattro?
If you have already purchased some flywheel - what size clutch it supports - 228 mm or 240mm?
Old 06-08-13, 04:29 PM   #3
And actually - why are you asking us the code of your gearbox - you have the car, so while we can only guess, you can read that goddamn code. It's on top of the bellhousing, straight after the engine.
Old 06-08-13, 04:47 PM   #4
BryFlyinBy
BryFlyinBy's Avatar
Hi MSH
Fair point on the gearbox code - I wasn't aware it was stamped anywhere I could see it, admittedly I could have looked first!!
The clutch kit I purchased was a complete package, lightened Flywheel, Friction and cover plate, no where on the invoice or documents does it state the diameter and I didnt measure it before fitting, which is annoying. So I cant tell you.
What I do know is I think I'm going to remove the whole kit andask for my money back so I will be requiring a new flywheel and all clutch parts.
Thanks
Bry
Old 06-08-13, 04:58 PM   #5
lefthooker
Any chance you could be mistaking clutch slip for wheel spin? The fwd cars just don't seem to be able to handle much more than about 160/170 bhp, from what I've experienced.
Old 06-08-13, 06:04 PM   #6
BryFlyinBy
BryFlyinBy's Avatar
I wish!! At least that would put a smile on my face, no it was Dialynx who brought to my attention following the run to the MOT centre, and I have to trust their judgement.
Old 08-08-13, 02:31 PM   #7
PoloGaz
PoloGaz's Avatar
AXD or AXG is the code for the 20v FWD gearbox depending if it was from a 90/coupe respectively
I'll have to have a look at your build thread to see how you made it all work
PoloGaz is offline   Reply With Quote
Old 08-08-13, 07:11 PM   #8
BryFlyinBy
BryFlyinBy's Avatar
Thank you mate, for a straight forward answer that actually helps.
Any questions about the thread, fire away
Cheers
Bry
