Classic Audi » Technical » Mech/Tech » Suspension & Brakes » whats this sticky stuff?
Old 11-05-13, 02:44 PM   #1
Gaz
Gaz's Avatar
Exclamation whats this sticky stuff?
I've just bought a pair of rear BREMBO discs and pads but the discs have a thin layer of slightly brown tint sticky stuff on them? any ideas what it is? I thought it might be glue from when they sealed the box or something?
Should I clean it off with some spirit/turps before I fit them? or is it suppose to be on there?
Never done brakes before so thought I check first before getting the towel out and cleaning them up.
Old 11-05-13, 02:49 PM   #2
mk1mistry
Normally a grease protective coating from corrosion, Usally stored in damp warehouses,
bit of thinners will do a lavley job.
mk1mistry is offline   Reply With Quote
Old 11-05-13, 02:49 PM   #3
Get it cleaned off !!!!
Its just to stop them going rusty while they are in the shop. A can of brake cleaner is best but petrol will clean it off aswel. Dont get any on the pads either
Old 11-05-13, 03:01 PM   #4
Gaz
Gaz's Avatar
Question
thanks guys... will clean them up
just another quick question, my pads seem to have only come with two bolts (presumably these are for fixing the calliper to to the brackets)
will it be okay to just re use the old ones on the one side?
Old 11-05-13, 03:08 PM   #5
Yup, a wee bit thread-lock and they'll be fine.........or you could just remove the lower bolt and swing the caliper up so as not to disturb the upper bolt.
Old 13-05-13, 07:38 PM   #6
Gaz
Gaz's Avatar
Unhappy
cheers dudes..
UI was going to take the rear discs off today but unfortunatly it looks as though the discs wont come off on a C4 Quattro with out removing the brackets and I don't have an Alan Key that is big enough
Can anybody tell me off the top of there heads what size alan key i need to remove the brackets?
Its a 1997 C4 A6 tdi quattro Avant
Old 13-05-13, 09:37 PM   #7
Gaz
Gaz's Avatar
Wink
just had a google... Its an 8MM HEX socket I think? is that right?
