Classic Audi » Classifieds section » Cars For Sale » Prospeed S1
Old 05-12-12, 05:48 PM   #1
Hamish
Default Prospeed S1
Seller Type : Trader
Vehicle Model : S1 E2
Price : £185000
Just seen the Prospeed S1 hillclimb car is up for sale:
http://www.racecarsdirect.com/listin..._group_e1.html
Would need a lottery win, but what a spec!
Hamish is offline   Reply With Quote
Old 05-12-12, 05:59 PM   #2
4v6
Dear Santa..........
Old 05-12-12, 06:15 PM   #3
yours for £1 and six lucky numbers
Old 05-12-12, 07:14 PM   #4
Full body kit made of ultra lightweight carbon/kevlar panels. Integrated multipoint CrMo multipoint roll cage. Engine 770HP, 670Nm, Dry Sump System with 3 section oil pump and CNC machined light weight oil pan. Electrical water pump and special custom made aluminum water and oil cooler radiators. Ultra light weigh hydraulic pump. All fuel and oil lines are made in Goodridge PTF G-line utra light Kevlar hoses. Motec M600 engine management with antilag, launch control and data logging. Motec PDM 32 power distribution module. Motec SDL/SLM dash logger and display, with shift light module. Rychem military spec wirelooms, with DR25 tubing and Deutsch Autosport connectors. Intrax 4-way black titan, 52 mm adjustable custom made suspension with solid top mounts. CNC machined, from high grade aluminum, uprights with titanium bearing cage. CNC machined light weight wheel hubs. CrMo A arms with CNC machined adjustable aluminum mounting plates with spherical bearings joints. Adjustable front and rear anti roll bars. 9x17 Magnesium wheels. 6-speed dog box gear kit, and internal oil pump. Front, middle and rear LSD plate type, using RS2 rear diff. Hollow drive shafts made of high grade steel with F1 technology. Custom made carbon propshaft – rated at 9000 rpm. AP racing front monoblock 4-piston with 356 mm discs and custom bells. AP racing front monoblock 4-piston with 305 mm discs and custom bells. AP racing balance bar with memory and digital display. AP racing pedal box and master cylinders. Тitanium handbrake with AP racing master cylinder. Goodridge G-line brake lines with aluminium fittings. Interior: Fiberglass dashboard with flocking. Carbon instrument panel and central console. Carbon/kevlar rear, side panels and back firewall panels.Carbon footwell - driver and co-driver. Sparco SPA, ultra light carbon seat. Sparco lightweight seat belt. Sparco carbon steering wheel - 400gr. with quick release. Carbon fire extinguisher. Total weight 1020 kg.
I bet that lot probably cost nearly as much as the asking price!
Old 05-12-12, 08:48 PM   #5
Error404
Thobbing Member
Error404's Avatar
if you've seen the build thread its worth every penny. Epic
Error404 is offline   Reply With Quote
Old 05-12-12, 09:08 PM   #6
Error404
Thobbing Member
Error404's Avatar
http://www.prospeed.bg/bg/blog/2/15
