Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Where did my hydraulic fluid go?
Old 05-07-11, 08:05 PM   #1
whiffer
whiffer's Avatar
Default Where did my hydraulic fluid go?
So far I have learned that the hydraulic system on the type 44 200QT is as complicated as the workings of a woman's mind. Still, undaunted, I'm afraid I must fix the bastard.
When I bought the car the entire hydraulic system was empty the previous owner told me that the car had pissed all the oil out during the MOT test.
Anyway the question is which component is most likely to have failed?
Master cylinder
Accumulator
Steering rack
Can't think of another!
The car has self levelling suspension. Is the best way forward to fill it up with fluid and see which component has failed?
whiffer is offline   Reply With Quote
Old 05-07-11, 08:07 PM   #2
Look for the component swimming in hydaulic fluid could be a good starting point.
Old 05-07-11, 08:11 PM   #3
whiffer
whiffer's Avatar
I do believe you have got it Watson! only the oil buggered off bout 4 years ago so not too much of anything anywhere!
Old 05-07-11, 08:12 PM   #4
Martc
Black Coupe Collector
Martc's Avatar
clutch slave cylinder is another culprit look for fluid leaking from gearbox bell housing
95 UrS6
87 Coupe Quattro
Old 05-07-11, 08:13 PM   #5
A, a cunning plan Sir...
Fill it up again....
Old 05-07-11, 08:16 PM   #6
Phil Payne
Master cylinder
Accumulator
Steering rack
Not the master cylinder (it doesn't go there) but perhaps the servo. Unlikely, though.
Favourite is the pump - lots of reasons why the cap seals fail.
Run! Run like ****!
Yup - put some oil in and see what happens. There are cheaper alternatives you can use for diagnostics.
Old 05-07-11, 08:26 PM   #7
whiffer
whiffer's Avatar
Run! Run like ****!
Will be removing the self levelling suspension - from what I have read on the forum this may also be a nightmare - deep joy
Old 05-07-11, 08:32 PM   #8
Phil Payne
It's wonderful when it works, but it's high maintenance and some of the parts prices would bring tears to the eyes of a granite statue.
Old 05-07-11, 08:33 PM   #9
Phil Payne
Hydraulic oil? Clutch (on a RHD) has its own DoT4 supply.
Old 06-07-11, 11:28 AM   #10
ovalking
Like Phil says the pump is the favourite.
Rear struts is another component to check.
And the self-levelling is indeed good ... when it works.
The hydraulics is by far the worst system on my 100. Every component has required attention.
ovalking is offline   Reply With Quote
