-   -   hard brake pedal (http://www.classic-audi.co.uk/forum/showthread.php?t=4546)
damianshep 22-04-09 02:58 PM
hard brake pedal
hi there, just bought a 2.6e coupe and the brake pedal seems very hard.
I don't know if it's meant to be as I've been used to driving an Alfa gta, and the misses' megane, so if someone could advise.
is the pedal generally quite stiff on a 95 coupe with no ABS ( I think )?
first audi I've had since I sold my 85 sport 10 yeas ago and need some help/advice..
cheers
damianshep 29-04-09 08:44 AM
ok open the bonnet and it does have abs ( should have done that first )!!
but is the pedal normally quite hard?
Addicted 29-04-09 09:05 AM
No.
It may be that the ABS pump is faulty, gives the same symptoms as no servo...
Pete Reeve 29-04-09 11:05 AM
I think you will find it has an hydraulic servo and the Accumulator has failed £200
damianshep 29-04-09 02:02 PM
how do i make sure that it's the accumulator thingy???
Pete Reeve 29-04-09 02:07 PM
you have a hard pedal and feels like you have a block of wood stuck under it,have a look at this though
http://www.isham-research.co.uk/quat...assist_mb.html
damianshep 29-04-09 07:01 PM
so is it the same system in theory as the older models?
Pete Reeve 29-04-09 07:08 PM
Yes thats correct
