Not a problem as such...
1 Attachment(s)
Whilst taking the facia off from infront of the instrument cluster I noticed this (see attachment below). I've not seen this on any other coupes and I was wondering if anyone knew what it was for?
Been a while since I've had the dash off, but isn't the indicator relay mounted up the back there... Might be just loose, or it could be a bigger one, that doesn't fit in it's original position. Has the car got/had a towing bracket? Only they fitted different indicator relays to allow audible indication of the trailers lights working.
Its the indicator relay, there is a metal clip on the back of it, which is clipped to the back of the intrument cluster.
| All times are GMT. The time now is 08:41 AM. |
