Audi GT calipers
Hello, I am on the look out for audi gt/80 quattro calipers with carriers for 256mm vented brake disc.
Can anyone help? Cheers |
Brake Disc
Hi,
Just wondering if your still interested in brake front disc's and caliper's cause I have a set which I removed from my 1985 WR quattro last year. Thanks, Dec. |
I would be if Rob has sorted out what he needs. You have the carriers? As I have 239 solids
Golf G60 Mk2 discs go straight on with the right 4 stud pcd @ 280mm diameter. The calipers are easy to get (mk3 Golf cross matches) but the caliper carriers rarer and expensive - and don't bolt to the strut without an adaptor - so not a direct fit, but not impossible.
An alternative (which I did to my early Fi GT) is to fit MK2 Golf 16V discs (the right 4 stud 100mm pcd) @ 256mm diameter, with later 2.2kv GT or coupe quattro calipers and carriers satisfying the close 76mm caliper carrier to strut mounts - these carriers have a 853 615 125 part number and aren't handed. Calipers are 357 615 123 A (or 4 for the other side), easy and plentiful on the calipers - the carriers quite scarce. Standard brake hoses match up, and you have to adjust the rear brake proportioning valve a little. But someone on here may be able to help if you post a parts wanted ad. http://i65.tinypic.com/2zok9kx.jpg Amazing that even 256mm discs look small on it! |
Ur calipers will not work on my application as I was going to use the calipers for my sons mk2 polo. I have now bought g40 polo calipers. Regards. Rob |
| All times are GMT. The time now is 10:08 PM. |
