-   -   Boost Gauge Quiery (http://www.classic-audi.co.uk/forum/showthread.php?t=31213)
T0MME 19-10-14 04:39 PM
Boost Gauge Quiery
Hello,
just fitted a mechanical boost gauge to my 1.8t
engine off reads 0
engine running reads 20 vac
flooring it reads 0
surely it should go above 0?
I've tee pieced it between and inlet manifold and fuel rail
the car runs and drives fine, pulls strongly for a stock engine..
what am i doing wrong?
Val 19-10-14 04:56 PM
If car is in neutral gear, you can't over 0.
Read the gauge while driving.
T0MME 19-10-14 04:59 PM
yes have driven the car, still reading 0 boost
Val 19-10-14 05:04 PM
Have you pressure tested your intake system? Any faults in vcds?
Does inlet pipe between throttlebody and IC pressurize when runing engine at idle and opening throttle with other hand?
T0MME 19-10-14 05:07 PM
like i said the car drives fine with no loss of power so i presume the system has no leaks, cant hear any air leeks anywhere
Val 19-10-14 05:12 PM
Bad gauge?
T0MME 19-10-14 05:14 PM
brand new? shall email the supplier tomorrow, not had one before so not sure if thats how there ment to work
Val 19-10-14 05:19 PM
Hm. Take it off, stand against mirror, blow in it and you should see it go around +0.3...+0.5. Lets see what you're made of.
T0MME 19-10-14 05:21 PM
just tried that manged to get it off the zero, so that should be working
Val 19-10-14 05:25 PM
I surrender :)
