Mass Air Sensor cleaner
Chaps,
Is there an aerosol cleaner specifically for cleaning Mass Air Sensors? Is it available at Halfords etc? Thanks :tup: |
Save yourself some money take it off the car and use brake cleaner and use a cotton bud to do the little probes if you can get to them
Make sure it's dry before you put it back :tup: |
Hmmmm...... interesting...
I was going to use carb cleaner and or electrical contact cleaner but was led to believe they were too aggressive. Thanks :) |
I also clean out idle air control valves with brake cleaner works brilliantly
But it's all I've ever used on MAF's on call sorts of cars |
The stuff in this case is, of course, carb cleaner.
carb cleaner :tup:
Thank chaps... looks like finding a specific MAF cleaner ain't straightforward anyway.
:shake: |
| All times are GMT. The time now is 10:11 AM. |
