type 85 pedal box
I need the pedals and mountings from a type 85 :tup:
For the UR? Or will an S2 one do?
yes for the urq, not sure if a s2 one will bolt in or not?
It bolts in but you will need to make alterations to it to mount the steering column the same
ok I might just remove mine and get that sorted if I can't just get a stock one. Annoying thing is I binned one a while ago :wall:
I have got a pile of them mate, I will see if there is a typ85 one for you tomorrow
Acid
I have a pedal set up from a B2 Passat - do you think that will fit? Its in Swindon, so could save you a trip... |
I've got some on my 88 GT type 85 being broken. If they're easy enough to remove they're yours!
PM me if they're any use to you. Cheers Dave |
| All times are GMT. The time now is 12:47 PM. |
